@ Riogrande
Hallo Rio, ich brauche da offenbar noch einen Tip.
Ich hab readmqttbms und infinipoll10k_bms in der reihenfolge gestartet und bekomme das:
2023-07-15 08:34:00: DEBUG: PV_GES: 82.92
PHP Warning: fwrite() expects parameter 1 to be resource, bool given in /etc/infinipoll10/infinipoll10k_bms.php on line 791
2023-07-15 08:34:00: DEBUG: Wert ACV1: 234.3
2023-07-15 08:34:00: DEBUG: Wert ACV2: 234.8
2023-07-15 08:34:00: DEBUG: Wert ACV3: 236.5
2023-07-15 08:34:00: DEBUG: Wert ACC1: 0
2023-07-15 08:34:00: DEBUG: Wert ACC2: 0
2023-07-15 08:34:00: DEBUG: Wert ACC3: 0
2023-07-15 08:34:00: DEBUG: Wert ACF: 50
2023-07-15 08:34:00: DEBUG: Wert INTEMP: 032
2023-07-15 08:34:00: DEBUG: Wert BOOT: 032
2023-07-15 08:34:00: DEBUG: Wert DCINV1: 349.9
2023-07-15 08:34:00: DEBUG: Wert DCINV2: 534.3
2023-07-15 08:34:00: DEBUG: Wert DCINC1: 0.69
2023-07-15 08:34:00: DEBUG: Wert DCINC2: 0.87
2023-07-15 08:34:00: DEBUG: Wert DCPOW1: 00242
2023-07-15 08:34:00: DEBUG: Wert DCPOW2: 00471
2023-07-15 08:34:00: DEBUG: Wert BATTV: 52
2023-07-15 08:34:00: DEBUG: Wert BATTCHAMP: -6.3
2023-07-15 08:34:00: DEBUG: Wert BATTCAP: 066
2023-07-15 08:34:00: DEBUG: Wert BATTPOWER: -327.6
2023-07-15 08:34:00: DEBUG: Wert POWERDIR: input
2023-07-15 08:34:00: DEBUG: ges. PV in KWh: 82.92
2023-07-15 08:34:00: DEBUG: akt. Leistung in Watt: 713
2023-07-15 08:34:00: DEBUG: Batterie Status: Entladen
2023-07-15 08:34:00: DEBUG: daypower_old: 000920
2023-07-15 08:34:00: DEBUG: daypower: 000920
2023-07-15 08:34:00: DEBUG: daybase: 82
2023-07-15 08:34:00: DEBUG: EMINFO 1:1 ACT:00713 FEED:01238 RES:08762 5:1
2023-07-15 08:34:00: DEBUG: RTCP ^D0600 1 00000 00000 00000 0060 1 0000 00000 100 00000 000 000
2023-07-15 08:34:00: DEBUG: INGS ^D0560023 0023 0023 0004 0004 0003 3939 3939 3935 3938 000
2023-07-15 08:34:00: DEBUG: BMS ^D0520519 066 1 0004 00 0 0552 0552 1500 0 0 0504 0150
2023-07-15 08:34:00: DEBUG: DC:713 BATT:-327.6
2023-07-15 08:34:00: DEBUG: storage_dat: 20230715-08:34.00 -327.6 066
2023-07-15 08:34:02: ================================================
2023-07-15 08:34:02: DEBUG: Modus: Hybrid (Line mode, Grid mode)
BMS Commando:
BMS Battery Voltage: 0519
BMS Battery Percent: 066
BMS Battery Current: 1
BMS Warning Code : 0004
BMS Froce Charge : 00
BMS CV Voltage : 0
BMS Float Voltage : 0552
BMS Max.Charge Amps: 0552
BMS BatStopDiscFlag: 1500
BMS BatStopChgFlag : 0
BMS ButCutoffVolt : 0
BMS BatMaxDisChAmps: 0504
BMS 12: 0150
INGS Commando:
R_Inv_Curr 0023
S_Inv_Curr 0023
T_Inv_Curr 0023
R_Out_Curr 0004
S_Out_Curr 0005
T_Out_Curr 0003
PBus_Volt 3940
NBus_Volt 3939
PBusAvg_V 3938
NBusAvg_V 3938
NLine_Cur 000
RTCP: ^D0600 1 00000 00000 00000 0060 1 0000 00000 100 00000 000 000
EMINFO Commando:
EMFirst: 1
DefFeed-InPow: 15000
ActPvPow: 00719
ActFeedPow: 01245
ReservPow: 08755
EMLast: 1
Ich hab jetzt schon ein paar Tage drüber gebrütet, aber ich steck etwas fest.
Eventuell hast du oder ein anderer Softwarekönner einen Tip für mich.
Besten Dank
Dirk
