Hallo in die Runde,
hat jemand den Adapter mit einem 10E BMS am Laufen? Ich erhalte keine Werte.
Konsole sieht bei mir wie folgt aus:
19:58:42.273 MQT: Attempting connection...
19:58:42.308 MQT: Connected
19:58:42.313 MQT: tele/tasmota_303828/LWT = Online (retained)
19:58:42.315 MQT: cmnd/tasmota_303828/POWER =
19:58:42.334 MQT: tele/tasmota_303828/INFO1 = {"Info1":{"Module":"ESP32-DevKit","Version":"13.0.0(tasmota32)","FallbackTopic":"cmnd/DVES_303828_fb/","GroupTopic":"cmnd/tasmotas/"}}
19:58:42.350 MQT: tele/tasmota_303828/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-303828-6184","IPAddress":"192.168.178.51","IP6Global":"","IP6Local":"fe80::32c6:f7ff:fe30:3828"}}
19:58:42.368 MQT: tele/tasmota_303828/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":29}}
19:58:42.749 MQT: stat/tasmota_303828/RESULT = {"Command":"Error"}
19:58:42.799 MQT: stat/tasmota_303828/RESULT = {"Command":"Error"}
19:58:42.851 MQT: stat/tasmota_303828/RESULT = {"Command":"Error"}
19:58:44.379 MQT: stat/tasmota_303828/RESULT = {"Command":"Error"}
19:58:45.870 QPC: Reset
19:58:46.874 MQT: tele/tasmota_303828/STATE = {"Time":"2023-07-23T19:58:46","Uptime":"0T00:00:08","UptimeSec":8,"Heap":91,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":20,"Objects":294},"Wifi":{"AP":1,"SSId":"NaDb","BSSId":"34:81:C4:CB:C9:5B","Channel":13,"Mode":"11n","RSSI":100,"Signal":-30,"LinkCount":1,"Downtime":"0T00:00:03"}}
19:58:46.916 MQT: tele/tasmota_303828/SENSOR = {"Time":"2023-07-23T19:58:46","seplos":{}}
19:58:51.850 MQT: tasmota/discovery/30C6F7303828/config = {"ip":"192.168.178.51","dn":"Tasmota","fn":["Tasmota",null,null,null,null,null,null,null],"hn":"tasmota-303828-6184","mac":"30C6F7303828","md":"ESP32-DevKit","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"13.0.0","t":"tasmota_303828","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"sho":[],"sht":[],"ver":1} (retained)
19:58:51.934 MQT: tasmota/discovery/30C6F7303828/sensors = {"sn":{"Time":"2023-07-23T19:58:51","seplos":{}},"ver":1} (retained)
