Irgendwas funktioniert nicht, wenn ich den Code von AggregateBatterie oben im Beitrag einbinde (Beitrag wird dann "leer) - ich versuche es mal separat:
# Version 3.1
########## Hardware settings ##########
NR_OF_BATTERIES = 2 # Nr. of physical batteries to be aggregated. Smart shunt for battery current is not neede >
NR_OF_CELLS_PER_BATTERY = 16
NR_OF_MPPTS = 1 # Nr. of MPPTs
DC_LOADS = False # If DC loads with Smart Shunt present, can be used for total current measurement
INVERT_SMARTSHUNT = True # False: Current subtracted, True: Current added
############ DBus settings ############
BATTERY_SERVICE_NAME = 'com.victronenergy.battery' # Key world to identify services of physical Serial Batteries (and SmartShunt if available >
BATTERY_PRODUCT_NAME_PATH = '/ProductName' # Path of Battery Product Name
BATTERY_PRODUCT_NAME = 'SerialBattery' # Key world to identify the batteries (to exclude SmartShunt)
BATTERY_INSTANCE_NAME_PATH = '/CustomName' # if CustomName doesn't exist, set '/ProductName'
MULTI_KEY_WORD = 'com.victronenergy.vebus' # Key world to identify service of Multis/Quattros (or cluster of them)
MPPT_KEY_WORD = 'com.victronenergy.solarcharger' # Key world to identify services of solar chargers
SMARTSHUNT_NAME_KEY_WORD = 'SmartShunt' # Key world to identify services of SmartShunt
SEARCH_TRIALS = 10 # Trials to identify of all batteries before exit and restart
READ_TRIALS = 10 # Trials to get consistent data of all batteries before exit and restart
############## Options ################
CURRENT_FROM_VICTRON = True # If True, the current measurement by Multis/Quattros and MPPTs is taken instead of BMS.
# Necessary for JK BMS due to poor precision.
OWN_SOC = False # If True, the self calculated charge indicators are taken instead of BMS
ZERO_SOC = True # Allow zeroing charge counter at MIN_CELL_VOLTAGE. At full battery it is always set to 10 >
CHARGE_SAVE_PRECISION = 0.0025 # Trade-off between save precision and file access frequency
##### Charge/Discharge parameters #####
# Please note: Victron ESS disables CCL if DC-coupled PV feed-in is active. This program disables the DC-coupled PV feed-in when necessary.
OWN_CHARGE_PARAMETERS = True # Calculate own charge/discharge control parameters (True) from following settings
# or use them from battery driver (False)
BALANCING_VOLTAGE = 3.5 # This voltage per cell will be set periodically and kept until balancing below CELL_DIFF_ >
BALANCING_REPETITION = 10 # in days
CHARGE_VOLTAGE_LIST = [3.45, 3.45, 3.45, 3.50, 3.50, 3.50, 3.50, 3.50, 3.50, 3.50, 3.50, 3.50] # Set up how full the battery has to be charge >
# jan, feb, mar, apr, may, jun, jul, aug, sep, oct, nov, dec
MAX_CELL_VOLTAGE = 3.5 # If reached by 1-st cell, the CVL is dynamically limited. DC-coupled PV feed-in will be d >
MIN_CELL_VOLTAGE = 2.9 # If reached, discharge current set to zero
MIN_CELL_HYSTERESIS = 0.1 # Allow discharge above MIN_CELL_VOLTAGE + MIN_CELL_HYSTERESIS
CELL_DIFF_MAX = 0.015 # If lower: re-enable DC-coupled PV feed in (if was disabled by dynamic CVL reduction and >
BATTERY_EFFICIENCY = 0.98 # Ah fed into batteries are multiplied by efficiency
MAX_CHARGE_CURRENT = 160 # Max. charge current at normal conditions
MAX_DISCHARGE_CURRENT = 100 # Max. discharge current at normal conditions
# settings limiting charge and discharge current if at least one cell gets full or empty
# the lists may have any length, but the same length for voltage and current
# linear interpolation is used for values between
CELL_CHARGE_LIMITING_VOLTAGE = [MIN_CELL_VOLTAGE, MIN_CELL_VOLTAGE + 0.05, BALANCING_VOLTAGE - 0.1, BALANCING_VOLTAGE, MAX_CELL_VOLTAGE] # [min, . >
CELL_CHARGE_LIMITED_CURRENT = [0.2, 1, 1, 0.05, 0]
CELL_DISCHARGE_LIMITING_VOLTAGE = [MIN_CELL_VOLTAGE, MIN_CELL_VOLTAGE + 0.1, MIN_CELL_VOLTAGE + 0.2] # [min, ... ,max]
CELL_DISCHARGE_LIMITED_CURRENT = [0, 0.05, 1]
### if OWN_CHARGE_PARAMETERS = False ###
# If "False", the transmitted CVL is always the minimum of all batteries
# If "True", the transmitted CVL is the maximum of all batteries until all are in "float",
# than the minimum of all is taken. Attention: By using this function you rely on the functionality
# and correct settings of the SerialBattery driver. Set "True" only if you know exactly
# what you are doing. If not sure, keep it at "False".
KEEP_MAX_CVL = False
####### Logging and reporting #########
SEND_CELL_VOLTAGES = 0 # 0: Disable Cell Info in dbus, 1: Format: /Cell/BatteryName_Cell<ID>
LOGGING = 2 # 0: no logging, 1: print to console, 2: print to file
LOG_PERIOD = 900 # in seconds; if 0, periodic logging is disabled
