Seplos-Low Cost DIY LFP Batterie Kit Anbieter, MASON 48V Batterieboxen/M8 cable connector
DISCOUNT PRICE!
Seplos hat einige neue DIY-Kits für die meistverkauften LFP-Zellen auf dem Markt entwickelt.
MASON280 DIY kits( including 48V 200A BMS and Bluetooth display): EVE 280Ah/ EVE 304Ah/ EVE 280K/ GFB 280Ah/ LISHEN 280Ah
48V 16S version: USD480/unit (new BMS3.0 200A inside, free with one RS485 adapter)
Shipping cost by train DDP term to Germany: USD95/unit, Delivery time:35days (in stock and ready to ship)
Für große Bestellmenge, kontaktieren Sie mich bitte für einen Rabattpreis
Jerry Qiu / Sales Manager
+86 17688030917
2023 SEPLOS BROCHURE.pdf (2.86 MB)
Busbars mit doppelten Löchern für EVE LF280K Grade A
Seplos new vertical-type DIY kits for 280Ah cells. It fits less space room.
@jerry-seplos Hi Jerry - whats your idea about the pricing?
@arc we have price gradient for different order quantity? like wholesale price and distributor price
@jerry-seplos would you mind to publishing here?
For fishing you do need to offer a bite?
hello, are the new Seplos new vertical-type DIY kits for 280Ah cells also with yellow spacers and is it compressed and do it work together with the new terminals for the
Eve
battery
thank you
what is your message? Don’t get it.
finger weg von gehäusen mit liegenden zellen
will the new Seplos new vertical-type DIY work with Busbars mit double whole für EVE LF280K Grade A ?
Please see the post from March 14, there it is explicitly stated. (With picture)
Cheers
@eclipse for the black box, not the white
@schwuppe This MASON280 DIY box is suitable for EVE280K/280/304, CALT/CALB/LISHEN280 cells, and other cells that have similar dimensions (72mm174mm202mm)
@schwuppe yes, it is also compatible with EVE280K with double holes terminals
@arc
Please check the main post
Warum?
Ich empfehle die Benutzung der Suchfunktion hier mit den Stichwort "liegend".
There is no research or experimental evidence that flat placement of LFP prismatic aluminum shell cells can affect performance. If it does have a significant impact, the wall-mounted style battery packs will not be produced at all. The engineers of LFP cells manufacturer are more professional than you think
Hi Jerry,
you may read different scientific papers than we do.
Some weeks ago we discussed the case of how LIB shall be oriented in use based on some Chinese scientific paper.
The paper suggests that there is a difference in aging of the cell.
We also discussed failure mode of a cell when overpressure burst’s the safety valve. The overpressure causing the valve brake would spray out a significant the electrolyte when the cell is not standing up right. Unfortunately I can’t find the related paper here anymore.
Bottom line are there a many of different perspectives on this subject and we couldn’t find any common ground.
