Seplos-Low Cost DIY LFP Batterie Kit Anbieter, MASON 48V Batterieboxen/M8 cable connector
hello @Jerry-Seplos how can i order the box and how much is the shippling to Germany?
@schwuppe
hi, you can order from Seplos Alibaba online shop.And the shipping cost by train of one unit is about USD95 (DDP term, taxes included)
thank you
@schwuppe check your Alibaba
@jerry-seplos I can't find the train option on Alibaba, only express shipping which costs about the same as the whole unit. What am I not seeing?
@micxer Shipping by train does not mean there is a train express bill for the whole trip. The express shipment is the last distance from the railway terminal to your front door.
@micxer For the order of large DIY boxes or battery packs, you need to contact us on Alibaba first and do not just place the order by yourself
Hi Jerry,
a few month ago I bought a Seplos BMS 200A for my DIY 18650 powerwall. Now, after soldering 2800 cells and a lot of damaged ones, I decided not to build it with 18650 cells.
So is it possible to buy a case without an BMS?
Best regards
Andre
@hertmond
Hi, so which model (capacity, brand) prismatic LFP cell you are going to use to build the power wall?
@jerry-seplos
Hi, I want to use 280Ah EVE Cells.
@hertmond ok, I have sent PM to you
@Jerry-Seplos
Hello Jerry,
what is the difference between the MASON-206-16S-DIY kit and the MASON-48280-DIY?
Does one of them contains the new BMS3.0?
I need a DIY-Kit for EVE LF304 with double hole busbar.
Alex
@alexno
MASON206 and MASON280 are suitable for different dimension cells. We have not modified the MASON boxes to fit BMS3.0 (The BMS3.0 200A BMS has different size from the original BMS).
For your EVE304Ah cells, you need to choose Seplos MASON280 DIY kits
