You may use your Ampmeter, your Multimeter, range 200mA to connect .. Current has to be below, say, 50 mA. Then its ok. Ist the current Higher, disconnect immediately.
If you connect, the Zero Volt of the upper cell measurement should bei fixed immediately, das, 2 Seconds longest. Thats Shows im as well.
Hi, the only way i have been able to get the 16th cell not to give an error is to add another cell Temporarily. But this does not solve my issue. Any other ideas. As joining 15 and 16 does not resolve the problem.
It has the option to change the cell number to 15 but no indication of what to do with the 16th cable. Also i get a 0V on cell 16 that gives a cell error in the bms.
[/quote]
Ist ite an option INSIDE the parameters in the firmware? Set by App or pc?
The zero Volt display of cell 16 shows, that the BMS ist still in 16 cell mode. Did you switch it to 15 cells, or 15s?
Nunja, die firmware binaries von dimm enthält eine firmware für P13S120A...jetzt muss ich mal schauen wo ich eine firmware herbekomme die mein pack wieder nutzbar macht. Also Achtung!
Einer musste es ja testen! Doof das ich es war
edit.: also wenn einer was hat was ich nutzen könnte, immer her damit.
