ich werde morgen die Firmware testen... bin gespannt!
hallo the new firmware for victron 15.23 is no good for victron !!! look video
@thestefan hab gestern die 15.23 installiert - HW15 - noch keine einzelnen Zellen ersichtlich im Daisy-Chain Betrieb!
danke fürs Feedback....schade.
Hallo in die Runde! Und gleich mal ne Frage: Daisy-chain bedeutet, dass ich 2 Packs mit dem aktuellen JK-BMS in einem Victron-system betreiben kann. Ich spare mir also das Gefummel mit serialbattery?
hallo the bug for 15.23 please to firmware 15.24 for the andy ok
JKBMS-PBXX-V15.24.rar (213 KB)
Thank you a lot! We appreciate this direct communication. Beside the firmeware files the changelog is more value!
Is this fix for Deye inverter related to the "Force Charge Request" Bug?
V15.23 Upgrade logs 1. Optimize the alarm reporting logic of parallel current limiting module. 2. Optimize the JKBMS-CAN communication protocol. 3. JKBMS RS485_Modbus Add Buad9600bps. 4. Added support for JK-BD6A20S20P JK-BD6A24S20P. 5. fix a bug about DEYE inverter.
Ich bin mal so frei, Changelog ist im *.rar Archive, hier nochmals direkt zum Nachlesen
-V15.06 Upgrade logs 1.Fixed a bug where parameters were lost after BMS restart. The bug is caused by a logical error in the parameter entered by the user. 2.Change the default configuration parameters to LPF to improve security. 2.Optimized JKBMS Modbus protocol, added RCV RFV register support. The protocol must use the PC software version V2.5.0。 3.Fixed the Bug that the hardware version may be incorrect in the device information. 4.Add battery low temperature alarm to dry triggers. -@2024-01-09 by JKBMS -V15.09 Upgrade logs 1.Fix a bug, parameters (RFV Time) Storage failure. 2.Change the default configuration parameters to LTO to improve security. -@2024-01-12 by JKBMS -V15.10 Upgrade logs 1. Button shutdown logic detection and optimization. 2. Bluetooth communication optimization. -@2024-01-17 by JKBMS -V15.11 Upgrade logs 1. DRY Trigger source added "12 - Remote Control "option 2. The LCD V2.0 protocol is added to the protocol library, which supports charging and discharging through the touch screen. 3. The Victor protocol allows the vendor name to be changed by writing the user's private data. 4. Fix a bug, parameters (RFV Time) Storage failure. -@2024-03-01 by JKBMS V15.17 Upgrade logs 1. Upgrade the LCD protocol to support 1.1 and connection instructions. 2. Optimize the SWUART code. 3. Fix the Bug of the calf communication protocol. 4. Added support for JK-BD6A20S20P JK-BD6A24S20P. 5. Add intermittent alarm function. 6. Add the emergency trigger button and the emergency time parameter. 1. Added LUXPOWERTEK inverter support. @2024-03-31 by JKBMS V15.23 Upgrade logs 1. Optimize the alarm reporting logic of parallel current limiting module. 2. Optimize the JKBMS-CAN communication protocol. 3. JKBMS RS485_Modbus Add Buad9600bps. 4. Added support for JK-BD6A20S20P JK-BD6A24S20P. 5. fix a bug about DEYE inverter. @2024-05-27 by JKBMS V15.24 Upgrade logs 1. Fixed a Bug about LCD display in V15.23. @2024-06-04 by JKBMS
Wann machen die endlich den richtigen Cell high und low Voltage im Victron Parallel Betrieb?
Warte, ich hol mal schnell die Glaskugel…
im vergleich zu seplos mach jk schon sehr viel updates an der fw
seplos hat ja überhaupt nichts interessiert was die leute wollen
@xenonfoxone leider profitieren nicht alle von den updates - diejenigen mit fehlerhafter hardware können keine updates durchführen und jk verweigert den support
siehe JK Inverter BMS Update Fehler mit Crash / Shutdown - JK BMS - Akkudoktor Forum
Ich hab heute einen Fehler gefunden bez. Requestet Charge Voltage und Requestet Float Voltage.
Wenn die Charge Voltage erreicht wurde und das BMS in die Float Voltage wechselt bleibt es zb. ja für 8h in Float Voltage Bereich... hab ich aber zuhause einen Tag mit große Lasten die immer wieder Ein und Ausgehen und der Akku wird zb. auf 95% entladen... und später kommt wieder die Sonne... wechselt das BMS nicht mehr in die Charge Voltage zurück... erst wenn der Timer abgelaufen ist!
setze float auf irgendwas zwischen 3,37 und 3,4v/z dann ist der akku auch wieder voll
ist eigentlich auch besser so weil sonst dein akku ständig auf charge voltage hochgebracht wird. einmal am tag reicht es ja schon
Und die Käufer der JK Inverter BMS der ersten Version sind auch gelackmeiert:
Firmware 14.x wird seit Januar 2024 nicht mehr weiterentwickelt und Firmware 15.x läuft auf der Hardware nicht ![]()
habt ihr eigentlich auch kleine Spannungsunterschiede bei euren BMS gehabt?
Hab die neue HW-Version und gestern in Betrieb genommen. Multimeter und MPPT zeigen exakt die gleiche Gesamtspannung an, aber das BMS ist auf der Gesamtspannung um 0,2V weniger. Macht jetzt auf die einzelne Zellspannung nicht viel aus, aber eigentlich sollte das doch passen. Das BMS ist ja nur zum Spannung messen da, dann sollte es das ja genau können.
Die einzelnen Zellspannungen passen soweit auch, nur eben um paar mV zu wenig auf allen Zellen. Auf den Kabelschuhen der Messleitungen vom BMS hab ich auch die gleiche Spannung wie auf dem Terminal selbst, ist also ne saubere Verbindung.
Was macht das BMS wenn man die Spannung kalibriert? Man gibt ja nur die Gesamtspannung ein, aber dann müssten ja auch alle Zellspannungen angehoben werden oder?
Ansonsten läuft das BMS auf Anhieb super :d
@nightmarex2 ich kalibriere jedes BMS (egal welcher Hersteller) mit einem Labornetzteil. Bei meien JK-Inverter BMS waren es, 0,22V unterschied... eines hat zu viel angezeigt das andere zu wenig! Problem... du kommst zb. auch nicht auf die Requested Charge Voltage und das System geht nie in den Float Modus.
Und was kalibrierst du da?
Die Gesamtspannung und auch die Stromstärke? Hab gelesen das sich der Strom nicht genau kalibrieren lässt.
@nightmarex2 Spannung ist kein Problem ich mach das auch mit Labornetzteil + Multimeter.
Strom kann man leider nur in ganzen Ampere ohne Nachkommastellen eingeben. Ich hab das immer nur annäherungsweise hinbekommen.
Und was hat das mit Victron zu tun?
ich hab die bei mir drauf und nutze auch Victron und hab bis jetzt keine Probleme entdeckt
