Can a Victron MultiPlus-II 230V 48/5000/70-50 inverter be used to charge a battery in continuous operation for hours? Only us charger? Charging should only take place via AC current without the support of solar panels. Capacity battery 15 kWh. 280 AH und lifepo4 battery 16 S each 3.45 Volt charging
Yes ![]()
