Ist ein Trucki Stick mit Antenne.
Hier das log.txt:
log.txt created
Reset reason: Power On
00:00:02: Trucki2Shelly Gateway V: 1.14 06.12.2024 06:45
00:00:02: Reading configuration from flash...
00:00:02: Decrypting passwords
00:00:02: {
"encryptedpws": true,
"admin_pass": "",
"mqtt_pass": "*****",
"meter_pass": "",
"mqtt_server": "192.168.178.**",
"mqtt_port": "1883",
"mqtt_user": "***",
"hadiscovery": "0",
"readonly": "0",
"device_name": "T2SGneu",
"meter_url": "http://stromzahler.fritz.box/cm?cmnd=status%2010",
"json_keys": "StatusSNS,Energy,Power_curr",
"meter_interval": "500",
"meter_invert": "0",
"plugmode": "0",
"meter_user": "",
"maxPower": "800",
"vbatCutoff": "220",
"vbatReboot": "260",
"vbatFull": "00",
"vbatNormal": "00",
"zepc_target": "0",
"zepc_targetfull": "-600",
"zepc_average": "10",
"zepc_feedback": "0",
"sun2_on": "75",
"sun3_on": "75",
"sun2_off": "50",
"sun3_off": "50",
"sun2_ip": "",
"sun3_ip": "",
"night_maxPower": "300",
"night_begin": "00:00",
"night_end": "00:00",
"ntpserver": "pool.ntp.org",
"timezone": "CET-1CEST,M3.5.0/02,M10.5.0/03",
"darktheme": "0",
"ip": "0.0.0.0",
"gateway": "0.0.0.0",
"subnet": "0.0.0.0",
"dns": "0.0.0.0",
"dhcp": "1",
"accesspoint": "1"
00:00:03: VBATNORMALURL: http://192.168.1.xxx/relay/0?turn=off
00:00:04: VBATFULLURL: http://192.168.1.xxx/relay/0?turn=on
00:00:04: WIFI SSID: Schroeders Power Wlan WIFI PASS: ********
00:00:04: T2SGneu AP startet with IP: 192.168.4.1
00:00:05: WiFi interface init mode: AP_STA
00:00:05: DNS Server started for captive portal
00:00:05: ESP8285 Wifi connect->disconnect(true)
00:00:05: Wifi SSID loaded
00:00:05: Scanning for strongest accesspoint...
00:00:06: Scanning finished
00:00:08: SSID ; AP MAC ; RSSI[%]
00:00:09: *** Wlan ; 1C:ED:6F:A1:**:** ; -50 dbm
00:00:09: *** Wlan ; 44:4E:6D:67:2B:** ; -64 dbm
00:00:09: Shelly*** ; 60:55:F9:99:ED:** ; -58 dbm
00:00:10: Strongest AP MAC: 1C:ED:6F:A1:**:**
00:00:10: IP Configuration:
00:00:10: DHCP enabled
00:00:10: ip: (IP unset) Config: 0.0.0.0
00:00:11: gw: (IP unset) Config: 0.0.0.0
00:00:11: sn: (IP unset) Config: 0.0.0.0
00:00:11: dns: (IP unset) Config: 0.0.0.0
00:00:11: No DNS configured
00:00:12: Connecting to WiFi: *** Wlan WIFIPASS: ******** AP MAC: 1C:ED:6F:A1:**:** try: 0
00:00:12: WiFi mode: AP_STA
00:00:13: Webserver begin
00:00:13: Yeh WiFi connected. IP address: 192.168.178.* SSID: *** Wlan
16:40:04: RSSI: -55 dbm
16:40:04: BSSID: 1C:ED:6F:A1:**:**
16:40:04: mqtt connected
16:40:04: mqtt subscribed to T2SGneu/ACSETPOINTOVR
16:40:05: mqtt subscribed to T2SGneu/DACOVR
16:40:05: mqtt subscribed to T2SGneu/CALSTEPOVR
16:40:05: mqtt subscribed to T2SGneu/METEROVR
16:40:06: mqtt subscribed to T2SGneu/MAXPOWEROVR
16:40:06: mqtt subscribed to T2SGneu/TARGETOVR
16:40:06: mqtt subscribed to T2SGneu/ZEPCOVR
16:40:06: Now listening at IP 192.168.178.* UDP port 4210
16:40:07: Night timer disabled
18:40:07: NTP server IP: 185.13.148.71
18:40:07: NTP server date/time: 2025-4-22 (day) 18:40
18:40:08: Http connected to meter: http://stromzahler.fritz.box/cm?cmnd=status%2010
18:40:08: Http code OK: 200
18:40:08: Received Meter data: {"StatusSNS":{"Time":"2025-04-22T18:40:08","Energy":{"Power_curr":298,"energy_sum":****,"energy_supply":22.77,"Power_l1":18,"Strom_l1":0.19,"V_l1":233,"Power_l2":87,"Strom_l2":0.66,"V_l2":233,"Power_l3":189,"Strom_l3":1.25,"V_l3":232.3,"Hz":50}}}
18:40:09: Json Keys: StatusSNS,Energy,Power_curr
18:40:09: Meter power: 298.00
18:40:09: Modbus: Connected to SUN
18:40:10: Energydata loaded from file:
18:40:13: meter day engery: 0.49[kWh]
18:40:13: last saved: 2025-4-21 10:24:42
18:40:15: Engery counter reset. Last Date:2025-4-21 10:24:42
18:40:16: METER engery reset: 0.5kWh -> 0kWh
18:40:16: {
"admin_pass": "",
"meter_pass": "",
"mqtt_user": "qwert",
"hadiscovery": "0",
"readonly": "0",
"device_name": "T2SG",
"meter_interval": "1000",
"plugmode": "0",
"meter_user": "",
"maxPower": "800",
"vbatFull": "0",
"vbatNormal": "0",
"zepc_target": "0",
"sun2_on": "75",
"sun3_on": "75",
"sun2_off": "50",
"sun3_off": "50",
"sun2_ip": "",
"sun3_ip": "",
"darktheme": "0",
"ip": "0.0.0.0",
"dns": "0.0.0.0",
"dhcp": "1",
"accesspoint": "1"
23:44:21: Engery counter reset. Last Date:2025-4-22 18:40:15
00:00:00: METER engery reset: 1.5kWh -> 0kWh
00:00:00: set_ac_power [W*10]: 0
ac_power [W*10]: 0
vgrid [V*10]: 2320
vbat [V*10]: 265
dac: 0
temp [°C]: 5925 <---------- !!!
maxPower [W]: 800
power_limit [W*10]: 0
total_energy [kwh*10]: 914.00
day_energy [kwh*10]: 0.00
mqtt_ACSetpointOVR:
mqtt_DACOVR:
mqtt_CALSTEPOVR:
mqtt_METEROVR:
mqtt_MAXPOWEROVR:
mqtt_TARGETOVR:
zepc_power [W*10]: 0
meter_power [W]: 172.00
sun2_ac_power [W*10]: 0
sun3_ac_power [W*10]: 0
sun2_ac_setpoint [W*10]: 0
sun3_ac_setpoint [W*10]: 0
sun2_roundtrip [ms]: 0
sun3_roundtrip [ms]: 0
meter_readout [ms]: 140
Webinterface:
T2SG/ACSETPOINT 44W
T2SG/ACDISPLAY 0W
T2SG/VGRID 232V
T2SG/VBAT 26.0V
T2SG/DAC 0
T2SG/CALSTEP 0
T2SG/TEMPERATURE 5925 °C
T2SG/METER 142.00 W
T2SG/MAXPOWER 800 W
T2SG/TARGET 30 W
T2SG/DAYENERGY 0 kWh
T2SG/TOTALENERGY 91.4 kWh
T2SG/STATE OFF
T2SG/ZEPC (ENABLED) 1
