ich habe heute etwas an der Software rumgespielt und wollte die Version von mr-manuel installieren.
Nun bekomm ich folgende Fehlermeldungen im Log:
@400000006442ca2815faa004 + python /opt/victronenergy/dbus-serialbattery/dbus-serialbattery.py /dev/ttyUSB0 @400000006442ca293815b05c INFO:SerialBattery:Starting dbus-serialbattery @400000006442ca293825311c INFO:SerialBattery:dbus-serialbattery v1.0.0-issue-421-20230317-1 @400000006442ca29382c747c INFO:SerialBattery:Testing LltJbd @400000006442ca2a0cb2cd14 ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a0ccb98bc INFO:SerialBattery:Testing Ant @400000006442ca2a1d68ffd4 ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a1d914854 ERROR:SerialBattery:>>> ERROR: Incorrect Data @400000006442ca2a1d916b7c INFO:SerialBattery:Testing Daly @400000006442ca2a2dc05d3c ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a2de3cf74 INFO:SerialBattery:Testing Daly @400000006442ca2b0351b17c ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2b03667db4 INFO:SerialBattery:Testing Jkbms @400000006442ca2b06478564 INFO:SerialBattery:Connection established to Jkbms @400000006442ca2b064e6eec INFO:SerialBattery:Battery Jkbms connected to dbus from /dev/ttyUSB0 @400000006442ca2b0654c404 INFO:SerialBattery:========== Settings ========== @400000006442ca2b065debc4 INFO:SerialBattery:> Connection voltage: 53.02V | Current: -0.0A | SoC: 94% @400000006442ca2b0664584c INFO:SerialBattery:> Cell count: 16 | Cells populated: 0 @400000006442ca2b066acca4 INFO:SerialBattery:> LINEAR LIMITATION ENABLE: False @400000006442ca2b0671603c INFO:SerialBattery:> MAX BATTERY CHARGE CURRENT: 35.0A | MAX BATTERY DISCHARGE CURRENT: 55.0A @400000006442ca2b0677a1cc INFO:SerialBattery:> CVCM: False @400000006442ca2b067e54a4 INFO:SerialBattery:> MIN CELL VOLTAGE: 2.9V | MAX CELL VOLTAGE: 3.45V @400000006442ca2b0684f7dc INFO:SerialBattery:> CCCM CV: True | DCCM CV: True @400000006442ca2b068b50dc INFO:SerialBattery:> CCCM T: True | DCCM T: True @400000006442ca2b0691c14c INFO:SerialBattery:> CCCM SOC: True | DCCM SOC: True @400000006442ca2b0907d9fc INFO:SerialBattery:DeviceInstance = 1 @400000006442ca2b090f2914 INFO:SerialBattery:com.victronenergy.battery.ttyUSB0 @400000006442ca2b0a5608c4 INFO:SerialBattery:publish config values = 1 @400000006442cc5e0755961c + test -e /dev/ttyUSB0 @400000006442cc5e0755ad8c + cleanup @400000006442cc5e0755b55c + unlock_tty ttyUSB0 @400000006442cc5e0755bd2c + rm -f /var/lock/serial-starter/ttyUSB0 @400000006442cc8106af28a4 ./run: line 3: /opt/victronenergy/dbus-serialbattery/start-serialbattery.sh: No such file or directory @400000006442d04d29c36224 *** CCGX booted (0) *** @400000006442d50a11df37dc *** CCGX booted (0) ***
Die Datei /opt/victronenergy/dbus-serialbattery/start-serialbattery.sh liegt aber dort. Irgendwas hab ich zerschossen.
Wie kann ich den Fehler finden?
Danke
