szech
(Stefan)
12. November 2026 um 15:28
21
Maseb:
Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x5e74366eae0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) inside the event loop by custom integration 'eos_energiezentrale' at custom_components/eos_energiezentrale/energy/plugins/goe_http_v2.py, line 47: self.opener=build_opener(ProxyHandler({}),NoRedirect()) (offender: /usr/local/lib/python3.14/ssl.py, line 736: context.load_default_certs(purpose)), please create a bug report at Issues · szech77/HA_EOS_Akkodoktor_Energiezentrale · GitHub For developers, please see Blocking operations | Home Assistant Contributors Traceback (most recent call last): File "", line 203, in _run_module_as_main File "", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/_main _.py", line 226, in sys.exit(main()) File "/usr/src/homeassistant/homeassistant/_main _.py", line 212, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 280, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.14/asyncio/base_events.py", line 707, in run_until_complete self.run_forever() File "/usr/local/lib/python3.14/asyncio/base_events.py", line 678, in run_forever self._run_once() File "/usr/local/lib/python3.14/asyncio/base_events.py", line 2064, in _run_once handle._run() File "/usr/local/lib/python3.14/asyncio/events.py", line 94, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.14/site-packages/aiohttp/web_protocol.py", line 678, in start task = asyncio.create_task(coro, eager_start=True) File "/usr/local/lib/python3.14/asyncio/tasks.py", line 395, in create_task return loop.create_task(coro, **kwargs) File
Sieht so aus, als hätte die Anbindung an den Go-e-Charger ein Problem. Ich habe ein Bugfix mit Version 0.17.1 bereitgestellt. Kannst du das bitte installieren und prüfen ob der Fehler behoben ist?
maseb
(Maseb)
12. November 2026 um 17:38
22
Hallo Stefan,
das Log ist leer. Keine Fehler.
Bleibt noch
Einrichtung in Home Assistant
Akkudoktor EOS
Plan verfügbar
InfluxDB
Lokaler Verlauf
Configured devices
Ladebegrenzung: Ja · Entladebegrenzung: Ja · Netzladung: Ja · Akku-Einspeisung: Nein · Speicher-Ladeleistung, Speicher-Entladeleistung, Speicher-SoC, Netzanschlussleistung, Hausverbrauch, PV-Leistung
go-e Charger – lokale HTTP-API v2
Phasenumschaltung: Ja · Absteckbares Ladegerät: Ja · Fahrzeug-Ladeleistung
Anlagengeräte
1 Geräte, 1 Speicher · Gemeinsame Speicherkapazität: 30 kWh
Victron Zuhause
Victron GX direct Modbus TCP · PV und Speicher · PV — · AC — · SoC — · Messwerte unvollständig
Grusss
Rudi
szech
(Stefan)
12. November 2026 um 17:47
23
Hallo Rudi,
bitte prüfen, ob du Victron korrekt eingerichtet hast. Anleitung: HA_EOS_Akkodoktor_Energiezentrale/VICTRON_MODBUS.md at main · szech77/HA_EOS_Akkodoktor_Energiezentrale · GitHub
Wenn das geprüft ist, dann bitte folgendes schicken:
Diagnosedaten unter "Einstellungen" -> Geräte & Dienste -> EOS Energiezentrale über die drei Punkte des Eintrags EOS Energiezentrale neben dem Zahnrad für die Einstellungen
Debug-Logs: In der selben Ansicht, aber über die drei punkte oben rechts
maseb
(Maseb)
13. November 2026 um 09:17
24
Hallo Stefan,
ich habe die Konfiguration mehrere Male gecheckt. Ich finde da keine falsche Angabe.
Zumal mit der Modbus Anbindung keine Eintitäten benötigt werden.
EOS Energiezentrale bringt noch folgende Meldung
Akkudoktor EOS
Plan verfügbar
InfluxDB
Lokaler Verlauf
Configured devices
Ladebegrenzung: Nein · Entladebegrenzung: Nein · Netzladung: Nein · Akku-Einspeisung: Nein · Speicher-Ladeleistung, Speicher-Entladeleistung, Speicher-SoC, Netzanschlussleistung, Hausverbrauch, PV-Leistung
Anlagengeräte
Victron Zuhause
Die log Datei konnte ich wegen der Größe nicht hochladen
Gruss Rudi
config_entry-eos_energiezentrale-01M738N0FKA1HSW0EKG0N9YNAW (5).json.txt (9,6 KB)
szech
(Stefan)
13. November 2026 um 10:52
25
Hallo Rudi,
ich hab ein neues Update bereitgestellt, 0.17.3. Bitte testen. Denn ich hab ja leider kein Victron-System. Daher ist dieses Plugin im Moment ja für dich bereitgestellt. Bei Erfolg bitte auch eine Rückmeldung geben, damit ich weiß, dass das Plugin erfolgreich getestet ist.
Außerdem eine Anleitung, mit der du genauer deine Konfiguration prüfen kannst:
# Victron GX direkt über Modbus TCP
Das Plugin **Victron GX direct Modbus TCP** (`victron_modbus`) verbindet sich lokal
mit dem GX-Gerät. Es benötigt keine zusätzliche Victron-HA-Integration, MQTT-
Verbindung, VRM-Anmeldung oder HA-Sensoren. Bestehende HA-/HACS-Plugins bleiben
unverändert verfügbar. Die synchronen Modbus-Abfragen laufen im HA-Executor.
## Voraussetzungen und Einrichtung
1. Venus OS **3.50 oder neuer**, GX mit Systemdienst und unterstützten Registern.
Am GX unter **Einstellungen → Dienste → Modbus TCP** den Dienst aktivieren.
Nur im vertrauenswürdigen lokalen Netz verwenden; keine Internetfreigabe.
2. Unter **Inbetriebnahme → Geräte → Gerät hinzufügen → Speicher/Hybrid-Wechselrichter**
das Plugin wählen. GX-IP/Hostname und Port (Standard 502) eintragen.
Systemmessungen und ESS verwenden fest **Unit-ID 100**; die einzelnen
Wechselrichter-/Batterie-Unit-IDs müssen nicht eingegeben werden.
3. **Phasen:** eine oder drei, passend zur gesamten Anlage. Nur vorhandene
PV-Quellen einschalten: DC-PV ist vorbelegt, AC-PV am Eingang und Ausgang
werden separat aktiviert. Ohne PV alle drei Quellen abschalten.
Die Werte sind Leistungen in W, keine täglichen Energiezähler.
Diese Datei wurde abgeschnitten. Original zeigen
szech
(Stefan)
13. November 2026 um 13:15
26
Ich würde mich allgemein übrigens auch über Infos freuen, ob es schon jemand zum laufen gebracht hat und ob es Verbesserungsvorschläge gibt. Bugs und Feature Requests aber gerne direkt als Issue im Github-Repo.
