hallo
Ich habe mir ein ESP32 gekauft und geflasht...
Der Sketch verwendet 1435486 Bytes (73%) des Programmspeicherplatzes. Das Maximum sind 1966080 Bytes. Globale Variablen verwenden 55648 Bytes (16%) des dynamischen Speichers, 272032 Bytes für lokale Variablen verbleiben. Das Maximum sind 327680 Bytes. esptool.py v3.0-dev Serial port COM13 Connecting........_____....._____.....___ Chip is ESP32-D0WD-V3 (revision 3) Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None Crystal is 40MHz MAC: c8:f0:9e:50:62:58 Uploading stub... Running stub... Stub running... Changing baud rate to 921600 Changed. Configuring flash size... Auto-detected Flash size: 4MB Compressed 8192 bytes to 47... Writing at 0x0000e000... (100 %) Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 1394.4 kbit/s)... Hash of data verified. Compressed 18656 bytes to 12053... Writing at 0x00001000... (100 %) Wrote 18656 bytes (12053 compressed) at 0x00001000 in 0.2 seconds (effective 811.1 kbit/s)... Hash of data verified. Compressed 1435600 bytes to 863164... Writing at 0x00010000... (1 %) Writing at 0x00014000... (3 %) Writing at 0x00018000... (5 %) Writing at 0x0001c000... (7 %) Writing at 0x00020000... (9 %) Writing at 0x00024000... (11 %) Writing at 0x00028000... (13 %) Writing at 0x0002c000... (15 %) Writing at 0x00030000... (16 %) Writing at 0x00034000... (18 %) Writing at 0x00038000... (20 %) Writing at 0x0003c000... (22 %) Writing at 0x00040000... (24 %) Writing at 0x00044000... (26 %) Writing at 0x00048000... (28 %) Writing at 0x0004c000... (30 %) Writing at 0x00050000... (32 %) Writing at 0x00054000... (33 %) Writing at 0x00058000... (35 %) Writing at 0x0005c000... (37 %) Writing at 0x00060000... (39 %) Writing at 0x00064000... (41 %) Writing at 0x00068000... (43 %) Writing at 0x0006c000... (45 %) Writing at 0x00070000... (47 %) Writing at 0x00074000... (49 %) Writing at 0x00078000... (50 %) Writing at 0x0007c000... (52 %) Writing at 0x00080000... (54 %) Writing at 0x00084000... (56 %) Writing at 0x00088000... (58 %) Writing at 0x0008c000... (60 %) Writing at 0x00090000... (62 %) Writing at 0x00094000... (64 %) Writing at 0x00098000... (66 %) Writing at 0x0009c000... (67 %) Writing at 0x000a0000... (69 %) Writing at 0x000a4000... (71 %) Writing at 0x000a8000... (73 %) Writing at 0x000ac000... (75 %) Writing at 0x000b0000... (77 %) Writing at 0x000b4000... (79 %) Writing at 0x000b8000... (81 %) Writing at 0x000bc000... (83 %) Writing at 0x000c0000... (84 %) Writing at 0x000c4000... (86 %) Writing at 0x000c8000... (88 %) Writing at 0x000cc000... (90 %) Writing at 0x000d0000... (92 %) Writing at 0x000d4000... (94 %) Writing at 0x000d8000... (96 %) Writing at 0x000dc000... (98 %) Writing at 0x000e0000... (100 %) Wrote 1435600 bytes (863164 compressed) at 0x00010000 in 15.2 seconds (effective 757.8 kbit/s)... Hash of data verified. Compressed 3072 bytes to 129... Writing at 0x00008000... (100 %) Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 396.4 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin..
#include "BLEDevice.h" #include <WiFi.h> #include <PubSubClient.h> #include <ESPmDNS.h> #include <WiFiUdp.h> #include <ArduinoOTA.h> #include "driver Link entfernt " #include "driver Link entfernt " #define SW_Version "3.6" bool debug_flg = true; bool debug_flg_full_log = false; //########### Settings beginnen ######### //OTA Setting #define OTA_Hostname "JKBMS" // -> hier ändern wenn OTA Name anders sein soll #define OTA_Passwort "" // -> hier ändern wenn OTA Passwort anders sein soll // MQTT Setting const char* mqtt_server = "192.168.0.69"; // -> hier die IP des MQTT Server eingeben const int mqtt_port = 1883; // -> hier den Port einstellen für den MQTT Server const char* mqtt_username = ""; // -> hier MQTT Benutzername eintragen const char* mqtt_passwort = ""; // -> hier MQTT Passwort eingeben String mqttname = "BMS_16P"; // -> hier wird der MQTT Gerätename festgelegt const int mqttpublishtime_offset = 10000; //-> hier einstellen wie oft Danten gesnedet werden sollen 1000 = jede Sekunde
mosquitto_sub -h localhost -v -t "#" BMS_Watchdog/status offline BMS_16P/status offline BMS_16P/Data/Zelle_01 3.294 BMS_16P/Data/Zelle_02 3.297 BMS_16P/Data/Zelle_03 3.297 BMS_16P/Data/Zelle_04 3.299 BMS_16P/Data/Zelle_05 3.297 BMS_16P/Data/Zelle_06 3.295 BMS_16P/Data/Zelle_07 3.295 BMS_16P/Data/Zelle_08 3.298 BMS_16P/Data/Zelle_09 3.294 BMS_16P/Data/Zelle_10 3.297 BMS_16P/Data/Zelle_11 3.295 BMS_16P/Data/Zelle_12 3.297 BMS_16P/Data/Zelle_13 3.298 BMS_16P/Data/Zelle_14 3.299 BMS_16P/Data/Zelle_15 3.297 BMS_16P/Data/Zelle_16 3.294 BMS_16P/Data/Battery_Voltage 52.747 BMS_16P/Data/Delta_Cell_Voltage 0.008 BMS_16P/Data/MOS_Temp 21.600 BMS_16P/Data/Battery_T1 22.100 BMS_16P/Data/Battery_T2 22.200 BMS_16P/Data/Battery_Power 692.246 BMS_16P/Data/Charge_Current -13.317 BMS_16P/Data/Percent_Remain 83 BMS_16P/Data/Cycle_Count 30 BMS_16P/Data/Balance_Current 0.000 BMS_16P/Uptime/Sekunde 46 BMS_16P/Uptime/Minuten 50 BMS_16P/Uptime/Stunden 17 BMS_16P/Uptime/Tage 152 BMS_16P/Data/Charge on BMS_16P/Data/Discharge on BMS_16P/BLEconnection connected BMS_16P/status onlineSoweit so gut ..
Jetzt möchte ich diese daten gerne in InfluxDB schreiben...
Ich nutze Solaranzeige multiregler Version,,,
Vielen Dank Vorab
