Hallo zusammen folgende Idee,
ich möchte gerne meinen Growatt direkt in VenusOS einbinden.
Aktuell bin ich soweit.
auf dem Modstick ist ESPhome und liest die Daten aus und sendet sie per MQTT an eine andere Steuerung. Bei mir IoBroker.
substitutions:
devicename: "esphome-growatt-01"
upper_devicename: "ESPHome Growatt 01"
esphome:
platform: ESP8266
board: esp07s
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
#api:
# password: "01234"
mqtt:
broker: 192.168.1.12
port: 1884
username: Nils
password: !secret mqtt_password
ota:
password: "01234"
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "GGrowatt"
password: "oLjULFvNXq1l"
# Enable Web server
web_server:
port: 80
captive_portal:
#time:
# - platform: homeassistant
# id: homeassistant_time
output:
# Blue Led
- id: light_bl
platform: gpio
pin: 16
# Green Led
- id: light_gr
platform: gpio
pin: 0
# Red Led
- id: light_rd
platform: gpio
pin: 2
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
# the Modbus device addr
address: 0x1
modbus_id: modbus1
update_interval: 10s
setup_priority: -10
sensor:
- platform: modbus_controller
address: 5
register_type: "read"
unit_of_measurement: W
device_class: power
icon: mdi:flash
value_type: U_DWORD
accuracy_decimals: 1
filters:
- multiply: 0.1
name: "${devicename} DcVoltage"
address: 3
unit_of_measurement: V
device_class: voltage
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} DcInputCurrent"
address: 4
unit_of_measurement: A
device_class: current
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcFrequency"
address: 37
unit_of_measurement: Hz
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${devicename} AcVoltage"
address: 38
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcOutputCurrent"
address: 39
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
address: 40
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} EnergyToday"
address: 53
unit_of_measurement: kWh
device_class: energy
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} EnergyTotal"
address: 55
state_class: total_increasing
icon: mdi:flash
value_type: U_DWORD
accuracy_decimals: 2
filters:
- multiply: 0.1
name: "${devicename} Temperature"
address: 93
unit_of_measurement: C
device_class: temperature
icon: mdi:thermometer
value_type: U_WORD
filters:
- multiply: 0.1
- platform: mqtt_subscribe
topic: the/topic
on_value:
then:
- lambda: |-
esphome::modbus_controller::ModbusController *controller = id(growatt);
uint16_t reg = 3; // Register: Max output active power (in %)
float value = id(mqtttest).state;
uint16_t register_value = static_cast<uint16_t>(value);
modbus_controller::ModbusCommandItem setOutputPower_command = modbus_controller::ModbusCommandItem::create_write_single_command(controller, reg, register_value);
controller->queue_command(setOutputPower_command);
#- platform: mqtt_subscribe
# name: "mqtttest"
# id: mqtttest
# topic: the/topic
# on_value:
# lambda: |-
# id(poweroutput).state;
#neu test power factor 02/2023
number:
name: "${devicename} Max Output Active Power"
address: 3
value_type: U_WORD
min_value: 0
max_value: 100
entity_category: config
step: 1
Die Ausgangsleistung des PV WR kann im Browser oder per mqtt geregelt werden.
Auf dem venus OS läuft ein mqtt treiber
https://github.com/mr-manuel/venus-os_dbus-mqtt-pv
Im IoBroker werden per Node Red die Werte an den Treiber geschickt. folgende Form hat das Json
msg.payload = {
"pv": {
"power": msg.payload["P"],
"voltage": msg.payload["V"],
"current": msg.payload["I"],
"energy_forward": msg.payload["W"],
"L1": {
Idee diee werte direkt von dem Modstick per mqtt ans Venus senden.
geänderter Code noch nicht getestet
address: 40
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
on_value:
- mqtt.publish_json:
topic: "Growatt/mic2000/meters"
payload: |-
return {"pv": {
power": id(pv_power).state,
"voltage": id(pv_voltage).state,
"current": id(pv_current).state,
"energy_forward": id(pv_energy_forward).state,
"L1": {
"power": id(pv_power).state,
Evtl. sieht ja jemand ob der code einen Fehler hat ich komme erst morgen zum testen und bin relativ neu in esphome.
