ich habe heute etwas an der Software rumgespielt und wollte die Version von
installieren.Nun bekomm ich folgende Fehlermeldungen im Log:
@400000006442ca2815faa004 + python /opt/victronenergy/dbus-serialbattery/dbus-serialbattery.py /dev/ttyUSB0 @400000006442ca293815b05c INFO:SerialBattery:Starting dbus-serialbattery @400000006442ca293825311c INFO:SerialBattery:dbus-serialbattery v1.0.0-issue-421-20230317-1 @400000006442ca29382c747c INFO:SerialBattery:Testing LltJbd @400000006442ca2a0cb2cd14 ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a0ccb98bc INFO:SerialBattery:Testing Ant @400000006442ca2a1d68ffd4 ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a1d914854 ERROR:SerialBattery:>>> ERROR: Incorrect Data @400000006442ca2a1d916b7c INFO:SerialBattery:Testing Daly @400000006442ca2a2dc05d3c ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2a2de3cf74 INFO:SerialBattery:Testing Daly @400000006442ca2b0351b17c ERROR:SerialBattery:>>> ERROR: No reply - returning @400000006442ca2b03667db4 INFO:SerialBattery:Testing Jkbms @400000006442ca2b06478564 INFO:SerialBattery:Connection established to Jkbms @400000006442ca2b064e6eec INFO:SerialBattery:Battery Jkbms connected to dbus from /dev/ttyUSB0 @400000006442ca2b0654c404 INFO:SerialBattery:========== Settings ========== @400000006442ca2b065debc4 INFO:SerialBattery:> Connection voltage: 53.02V | Current: -0.0A | SoC: 94% @400000006442ca2b0664584c INFO:SerialBattery:> Cell count: 16 | Cells populated: 0 @400000006442ca2b066acca4 INFO:SerialBattery:> LINEAR LIMITATION ENABLE: False @400000006442ca2b0671603c INFO:SerialBattery:> MAX BATTERY CHARGE CURRENT: 35.0A | MAX BATTERY DISCHARGE CURRENT: 55.0A @400000006442ca2b0677a1cc INFO:SerialBattery:> CVCM: False @400000006442ca2b067e54a4 INFO:SerialBattery:> MIN CELL VOLTAGE: 2.9V | MAX CELL VOLTAGE: 3.45V @400000006442ca2b0684f7dc INFO:SerialBattery:> CCCM CV: True | DCCM CV: True @400000006442ca2b068b50dc INFO:SerialBattery:> CCCM T: True | DCCM T: True @400000006442ca2b0691c14c INFO:SerialBattery:> CCCM SOC: True | DCCM SOC: True @400000006442ca2b0907d9fc INFO:SerialBattery:DeviceInstance = 1 @400000006442ca2b090f2914 INFO:SerialBattery:com.victronenergy.battery.ttyUSB0 @400000006442ca2b0a5608c4 INFO:SerialBattery:publish config values = 1 @400000006442cc5e0755961c + test -e /dev/ttyUSB0 @400000006442cc5e0755ad8c + cleanup @400000006442cc5e0755b55c + unlock_tty ttyUSB0 @400000006442cc5e0755bd2c + rm -f /var/lock/serial-starter/ttyUSB0 @400000006442cc8106af28a4 ./run: line 3: /opt/victronenergy/dbus-serialbattery/start-serialbattery.sh: No such file or directory @400000006442d04d29c36224 CCGX booted (0) @400000006442d50a11df37dc CCGX booted (0)
Die Datei /opt/victronenergy/dbus-serialbattery/start-serialbattery.sh liegt aber dort. Irgendwas hab ich zerschossen.
Wie kann ich den Fehler finden?
Danke
installierte PV: Fronius Symo 8.2-3-M + 38xJAM5(R)-72-210 (7,98kWp)
Hab heute mal alles neu aufgesetzt, man ist ja daran mittlerweile geübt.
War aber nicht von Erfolg gekrönt, immernoch der gleiche Stand.
Ist es möglich, dass es meinen DSD TECH SH-U09C3 zerlegt hat?
Blinken tut noch die RXD, TXD bleibt aus.
Aufgrund der Meldung würde ich noch mal kontrollieren (und das peinlich genau) ob der Eintrag zum Start des Treibers in der RC.Local auf den richtigen Pfad zeigt und die Rechte richtig gesetzt sind.
Ob der Adapter kaputt ist kannst Du an der Stelle gar nicht sehen. Das ist wenn im Log des Treibers zu sehen, wenn er denn mal gestartet ist.
hab das mehrmals gecheckt, die Datei ist dort und man kann sie dort auch starten.
Grad nochmal alles auf einem RPi4 installiert, dort funktionierts wohl.
Hier kann ich gleich mal die Bluetooth-Version testen.
Hast du es richtig deinstalliert oder nur deaktiviert mit dem Befehl "sh /data/etc/dbus-serialbattery/disabledriver.sh"?
Probier mal das hier und schmeiss alles komplett runter:
# handle read only mounts
sh /opt/victronenergy/swupdate-scripts/remount-rw.sh# remove files
rm -f /data/conf/serial-starter.d
rm -rf /opt/victronenergy/service/dbus-serialbattery
rm -rf /opt/victronenergy/service-templates/dbus-serialbattery
rm -rf /opt/victronenergy/dbus-serialbattery# kill if running
pkill -f "python .*/dbus-serialbattery.py"# remove install-script from rc.local
sed -i "/sh \/data\/etc\/dbus-serialbattery\/reinstalllocal.sh/d" /data/rc.local
Eine Neuinstallation auf einem RPi4 hat geholfen, per USB hab ich nun wieder Verbindung.
gestern wurde eine die offizelle Version v1.0.20230531 veröffentlicht.
Ich bin mir nicht ganz sicher, wie ich beim System von 0.14.3 Update. Muss ich vorher den alten Treiber deinstallieren oder kann ich das einfach drüberinstallieren?
@maik0815 einfach drüber
